Benefits (?) of TRX for cycling
#1
I eventually want to get into more “hardcore” weight lifting, but I am a total noob at this and would like to approach it having first built a decent foundation.
The gym I will go to offers TRX sessions and I am keen on starting with that in order to get a modicum of core functionality. And maybe after a couple months of that I’ll progress to a “proper”* weight lifting regime.
(a) Is TRX a valid option for the purpose I outline?
(b) Does the “plan” I am thinking of make sense for me?
Thanks in advance :slight_smile:
*one along the lines coach chad and others have proposed
#2
TRX is mostly core focused, so I’d say yes, there is a huge benefit for cyclists.
#3
TRX is great. You can get a good total body workout with it.
#4
The best thing about TRX is you can get a decent workout in your basement, or anywhere really. A full fledged gym plan would be great. But I get plenty of value from just doing a handful of basic exercises 3x per week at home. Everyone should have some TRX straps! (Or, get knock offs - there is no magic to the TRX brand. There are even directions online on how to make your own set for about $15)
BTW - Suspension strap work can be tough enough that you never have to “transition” to weights.
#5
Thanks guys.
It seems I will start off with TRX then, and dabble in weights later on
#6
TRX is great especially if you want to start strength training. I’ve had a bad habit of not keeping up with my strength so when I start back, I always start on the TRX so that I just don’t go and murder all my muscles by trying to do too much. The TRX helps keep me from doing that. Then when I move to weights, there are moves on the TRX that I continue to do because they are so good for the core and still hard.
#7
that is close to what I was thinking of. TRX can be a “bread and butter”, hopefully around the year foundation of core functionality, and weight lifting per se could serve to boost strength and strength-endurance (if I’m getting this right)
#8
While I love the TRX (or better termed ‘suspension training’) for the use of a stable platform and unstable body positioning, and the variety of uses/exercises you can do with it, I think we have to remember that it is a tool for training. While it is excellent for body weight exercises and ‘re’-learning fundamental movements, it lacks the ability to add external load. So, as you progress, I think you’ll need to look to add other tools (external loads, different exercises, maybe a gym membership). I would be hesitant to wait an entire year before introducing resistance training (if I understand your post correctly) as you’ll be missing out on the benefits that the external loading can do for you.
Great to see you adding to your toolbox!
#9
Hey gd
Actually I’m saying I’ll begin with TRX and start dabbling with larger (than body) weight-lifting about 4-8 weeks later. I agree with you on reaping the benefits of extra loads as soon as possible, but not before “relearning fundamental movements” :slight_smile:
