Ok so My mates who uses their old bike on indoor trainer says im crazy using new bike on kickr core?
Does this matter ive read on the internet this shud not give a problem. Or does it?
They say its bad for the frame that it is not designed for it.
Yes, I use my best bike. Itâs a Trek Madone 9 Project One. Over 300 TR workouts in the past year without issue. Unless youâre doing something silly (all out standing sprints) I wouldnât be worried.
I had strength sprints from a near-standing start prescribed on Tuesday in Jane Bald.
Dropped my chain in the middle one, and I noticed today that two teeth on the big ring seem to have been quite badly damaged. Oops - need to replace the chainring now
I have my top of the line carbon race bike on my Trainer. I train the way I race. Never an issue, but I also donât abuse it. I wouldnât do excessive rocking or hammer sprints out of the saddle viciously swaying the bike. I think just use some common sense and it will be fine.
There was maybe something about this a few weeks agoâŚ
I had emailed Specialized about their position regarding warranty should a frame get damaged from use in a trainer assuming it was correctly installed. They were suitably vague in their response, but reading between the lines they wouldnât replace it under warranty should there be an issue.
I also asked my dealer what his position would be, and they were of the view that you donât really get frames being broken on trainers, but donât be doing big out of the saddle sprint efforts.
The Road CC link above shows that some manufacturers are ok with trainer use, some not.
I donât know anyone that has damaged a frame using it sensibly in a turbo.
The view Iâve formed is that if there is something that may cause my frame to fail, if it does so whilst on a trainer, I might be up for a hard time trying to get it replaced under warranty. Previously I was using my good bike, but Iâve decided not to use anything I canât afford to replace on the trainer now.
Decent frame manufacturers will run their kit through a quality assurance process which essentially involves a machine which simulates the stresses of a rider doing thousands of kms.
Take a look if you can find footage. They are generally static machines which spin the cranks under force for long periods of time and it looks just like someone using a trainer.
Iâm not concerned about using my carbon frame and I donât really do all out sprint efforts indoors anyway.
I guess I also have more piece of mind that I have a MTB on the trainer. Worse case scenario I have to replace the back triangle and not the entire frame.
Hi, did ride my Cannondale Carbon Super Six since spring last year with over 5000 km and got no problems. I thinks its important to check if the bike is adjustested right on the trainer. I did run it on a Kickr.
Iâve seen lots of broken frames from crashes while riding outdoors, but never seen or heard of anyone damaging a frame riding it on the trainer. By that rationale youâd be crazy to ride your nice frame outside. Keep it for trainer only and ride the beater outside.
There is a HUGE difference from crashing (a random and hopefully rare occurrence) vs riding an indoor trainer (a common and weekly event). One is the exception, the other is the rule.
I used to use my tt bike on the turbo, sweat from the forehead dripped onto the front tyres and got into the front hub, which collapsed from corrosion on a tt, keep it covered up
