Extending Traditional Base HV Plans
I have decided to go the long and slow route this fall and do the traditional base HV plans. All three of them suggest that it could be a good idea for one reason or the other to add a fifth or even a sixth week to the blocks. How would you go about that? just repeat the last week of the plan or look for +1 +2 etc. modifications? Anybody done this before?
Hi @cyclhist,
I consider doing the same - maybe doing it like:
Week 1
Week 2
Week 2
Week 3
Week 3
is an option? When will you start?
Good luck! Would like to hear how it is coming along for you :slight_smile:
Before you begin you need to be sure that you can fulfill the time commitment 100% (at a minimum!) for the full 3-4 months. Since it’s intensity is static, Trad Base is wholly dependent on volume in order to make it work. If for any reason you don’t think you can do regular 12+ hour weeks, perhaps rethink the strategy.
Good luck!
