% FTP vs time relation
How long can average person sustain (theoretically) 90% FTP, 80% FTP, etc … Is out there any graph of this relation?
Example: If I plan 3 hour ride, what average %FTP can I aim at?
I put this info into my chart:
I pulled that info from the “Description” section in the following link:
I somewhere heard the following formula which seems like a reasonable rule of thumb giving some good starting point of orientation:
0.95^hours * FTP
Rizzi, what is ^ and *
Thanks
It’s the math meaning 0.95 to the power of “hours”, the multiplied by the rider FTP.
Ex: 0.95 ^ 1 hour X 200w FTP = 190w Average for the 1 hour
Ex: 0.95 ^ 2 hours X 200w FTP = 180w Average for the 2 hours
^ = to the power of / exponential
“*” = times
So with 300 FTP a ride for 3.5 hours would give
0.95^3,5 x 300 that is
0,835665780138059 x 300 = 250.7 Watt as coarse orientation.
Or simply 0.95^hours is the percent value for your FTP of that duration.
Of course it depends on the type of ride / terrain and so on if it’s a good match. But as said at least a good starting point.
Thanks Guys, that makes sense.
I do have another question - hope the OP does not mind.
I’m working with Virtual power, so don’t have a power meter. So if according to the above calculation for my target event is say 2 hrs @250 Watts - could I use my HR. I understand that their is a lag and its not as accurate as power but say I did 3 x 20min intervals at 250 Watts on my trainer - could I average out the HR from the 3 intervals and use this as rough guide to pace by.
With my limited experience it seems like a sensible rough approach but you should keep in mind that HR depends on many factors and could also be off that day. So with experience you might want to additionally or instead go with RPE.
I think it depends on each person and remember in the podcast some favored not to see HR so not to be influenced by numbers getting in your head.
@mcneese.chad might have some more elaborate info.
@Rizzi, you nailed it. I’d just take some mental notes on the trainer and play a bit outside. Know the variables and take as much as you can into that, and learn what really works for you.
So what about less than an hour? For example 40 mins?
It really varies from person to person and changes with training.
But roughly:
5 min = 120%
20 min = 105%
40-70 min = 100%
I’m actually off the scale at the short end. Few months ago had a 1s peak of 5.47 times estimated FTP. Unfortunately at 100s I am already quite average with 1.6 times FTP.
This is amazing, where did it come from?
I snagged it from somewhere in all the WKO4 launch materials, but don’t remember exactly where. An iLevels webinar, maybe?
So assuming those are SDs and not SEs, that would put you about the 95th percentile. Presumably sprinting us your strength?
yea, those bars are probably indicating a 95% range. But it is 2-sided, so that puts me out in the 97.5th percentile :slight_smile:
I just started with structured training after having cycled intensively for 3 years about 10 years ago. Funny thing is that although my FTP started from scratch again, my 5 second power was as strong as ever.
So I can imagine that with a few more months my FTP will go up, putting me closer in the normal range.
