Golden Cheetah v3.5 Released
Posting from Wattage google group:
It is available to download here: http://www.goldencheetah.org/#section-download
An overview of what’s new is available in video form here: https://vimeo.com/384576869
Main features in this release are:
  • Sync with major cloud services (Strava, Xert, TodaysPlan, SportTracks etc)
  • Banister Performance Modelling and Power Index
  • CP Performance Modelling with Performance Tests
  • Charting and Scripting with Python
  • Augment with HRV, RPE and Body Measures and Metrics
Does not work for bulk import of years of strava files unfortunately
Bummer, I’m out.
There are work arounds.
You can use https://tapiriik.com/ to sync to a dropbox folder and then import that locally.
You can also request your strava data. Though mine has 348 entries without a date which upsets GC greatly.
I just gave GC 1300 files and it chowed down on them just fine. I have to locate all the older ones and see how it’ll go
Correcting all those dates, no thanks
You do not need to re-import, downloading from strava works just fine.
  1. when synchronizing from the share menu change the dates (by default it has to/from for last month) and press refresh to get a full list.
  2. the auto sync at startup will only look for files in the last 30 days.
There are reports of Strava rate limiting at the moment due to high demand from our users, so it might be worth trying again later (if that is the root cause of the problem).
Mark
I’m very pleased to report that my issues ref Strava sync are over. Downloaded 3.5 and it connected to Strava first time of asking. Could never get it to work before.
