Hammer power supply is dunzo
trainer
#1
They are out of them on the Cyclops website (weak!!)…Do yall think it would be an issue just ordering one Amazon (same specs)? I really needed a ride tonight after a crap day at the office!
(if you are reading this Cycops rep, will my warranty be messed with)
#2
If you match the output specs it’ll be fine. You’ll have to match the end plug that goes into the trainer. Check that’s a standard size or you may have to get medieval with your blown power supply plug and hack it onto the new one.
#3
Had issues with my Cyclops Hammer, all pointed to the power supply. Checked output with a volt meter and it was pushing out power. Appears the socket in my cyclops is a bit dodgy, every few months it requires a wiggle. So if not already checked, bear that in mind!
One day I’ll get around to fixing it, when warranty expires… not worth the hassle of a return and being without it for a week!
#4
Good news! Cycleops came through and was able to find a power supply and hopefully it will ship out today. Great service on their part
#5
Hi guys,
I’m having some strange issues with the cord or socket. Sometimes the status LED is off, sometimes red and when i wiggle the cord or the plug it finally jumps to green. Is that something you were experiencing too?
#6
Yes, think the location of the plug isn’t great and all to easy to knock and damage. Either that or some design issue.
Like I mentioned before, something is possibly loose inside, dodgy wire connection or something similar on my one, will get around to checking/fixing once warranty expires. It’s only needed re plugging /wriggling a few times in last 3 months so for me its not worth the hassle of a return.
If yours is still under warranty and doing it lots then I would go down the warranty route asap.
#7
Just an update. In the end my plug was completely broken. As I’m living on a small island, sending the trainer in was no real option. I also was quite sure that the problem was with the plug or cable.
So I went to some electrician, showed him the power supply and he removed the plug and installed a new one. It’s a standard 5.5 mm x 2.1 mm connector. Did cost me less than $2. Now everything works like a charm again.
#8
Thanks for update… might get one of those ordered in for when I get around to replacing the plug and socket… in the last 3 months it’s gone off twice, annoying as you can lose 30 seconds in a Zwift event, wriggling it again an it comes back on… far from ideal !
#9
Yeah, before i could wiggle and wiggle. Now it sits tight again. So it was the plug and not the connector inside the trainer.
