Help: Best Plan Combo?
choosing-a-plan
#1
Yup, here we go again! Cuz I’m new to TR need the help of the experienced collective…
A Event/1st Peak is a TT. I want to totally dominate it. There, said it.
I’m almost done the SSB2 Low, TSS in the last week will be ~450.
I believe muscular endurance to be my top weakness.
I’m considering the following plan:
SSBase Low 1+2
Sustained Power Build Mid
SSBase High 1 or 2
SP Build High
TT Specialty
But…tinkering around today I came up with this idea:
SSBase Low 1+2
SSBase High 1+2
SP Build High
VO2max Block (2 weeks)
TT Specialty
Too Base heavy? Not enough Build? Too much too soon?
Ideas? Suggestions? Funny memes?
Thanks. :doughnut:
#2
Why not SSB medium? It has enough VO2.
I would advise against SSB High unless you know you can handle that amount of workload.
#3
True. And as with the SS Low plan, I just added supplementary workouts.
Would it be worth doing that much Base all at once (Option 2) or would I get more muscular endurance bang for my buck doing 2x Base+Build (Option 1)?
#4
If you have time for 5 blocks I would do
SSB MV 1-2
General Build MV
SSB MV 1-2
TT Speciality
#5
I’ll also add that if you have time for Traditional Base Mid for your first block, you can get a lot of productive work done with that as well
#6
I’m almost done SSB1+2 so no chance of doing Trad Base. Maybe next year I’ll do TB + strength training, hopefully it will wreck me less.
Due to extra workouts I put in, my SSB Low TSS (450) is currently between SSB MV 1-2 (427) and Gen Build MV (490)…I might require more stimulus in order to progress.
#7
If your FTP is increasing, you’ll be putting in more absolute load, so I wouldn’t be overly concerned with upping hours. Consistency is more important for getting through the Sustained and Speciality.
#8
Most people try to ramp annual hours too fast. A good target is around 50 extra annual hours per year.
