I have been using this carb source for many years during hockey games and in the gym. I started using it with electrolytes during my races and trainings a month a good and got great results out of it. I feel this carb source is way better than any glucose/fructose products. I was wondering if anyone here have tried it and got similar results.
The science behind this carb source seems to support a high effectivness for endurance sports. Maybe this could be a topic that @chad could dig in for a future podcast episode.
Colette on 01/07/2018|Question: Hi there, is HBCD free of lactose, dairy and gluten free?|
Answer: Hi Colette, our Highly Branched Cyclic Dextrin (Cluster Dextrin) is dairly and gluten free.
Perhaps the manufacturing starts with lactose, but the final product is something else. Really, it sounds like ucann superstarch and similar items. They compare themselves favorably vs waxy maize, similar to how ucann woud position itself. I’m guessing they just found a different way to manufacture it. I think ucann’s method is patented and uses heat, moisture and possibly pressure? And this products talks about an enzymatic process. It looks a lot cheaper, which is interesting.
I saw that too, and it is odd. But “dextrin” isn’t lactose. And this is the manufacturers website, so if they explicitly say it doesn’t have lactose then that’s pretty much from the horses mouth. I didn’t immediately see a nutrition label.
The “side effects” are the same things you’d see on pretty much any product… eg, placebo’s in drug trials usually have the same side effects. I’m sure plenty have reactions like this to certain gels, which is why there’s so much variation in what people prefer and tolerate.
I’ve started using cyclic dextrin and have had excellent results. I stomach it very easily compared with normal glucose or glucose fructose carb drinks. I’d be interested to hear of other people’s experiences too.
That’s interesting.
I was hoping this would be a cheaper alternative to the UCAN Superexpensive Superstarch, which I’m occasionally using. (I would probably use it more if it was cheaper). The main advantage of Superstarch is the more steady energy (blood glucose) levels. But it doesn’t seem that the highly branch cyclic dextrin has the same effect. Here’s a data on HBCD effects on blood glucose levels vs. maltodextrin and it seems to be essentially the same.
Looks like the advantage of the HBCD is the lower osmotic pressure which allows faster gastric emptying and presumably less stomach issues if you need to take in a lot of carbs.
Have you looked at waxy maize starch or vitargo as an alternative? Not sure where you’re based but find a supplier like myprotein where you can just buy a big unbranded bag and it should be cheaper than buying a run/bike specific brand
Vitargo seems to raise blood glucose fast and high, so not a good option for my purpose.
I wasn’t aware of Waxy Maize either and it is confusing. It is marketed as a fast carbohydrate but according to scientific studies it actually is a slow one. https://www.bodybuilding.com/fun/waxy_maize_starch_myth.htm I definitely want to try this one. It costs about 1/10th of what superstarch costs so if it works, it would be great! I wonder if you can make a gel out of it.
I suspect the starch will separate out from the water and it will need to be agitated before you consume it. Cooking it will cause it to gel up, but I believe that breaks down the starch which defeats the point of using/buying a complex starch in the first place.
