Dude. Spot on. Love that kit BTW. Great organization.
Great recommendations for building a kit.
I would encourage that while multi-tools often look attractive for the price/usability they tend to end up doing neither purpose that well (there are some exceptions).
I acquire a new tool if, (a) buying the tool is cheaper than paying a shop, and (b) Iâll use it at least once every few years. Iâm not trying to stiff my LBS, I just enjoy working on my bike.
There was a reference to bike tool that you could use to adjust seat angles using a tool that also went into the centre of the bottom bracket of the crankshaft on the pod cast. Still cant find a reference to it. Any advice would be appreciated
Some tools I like:
Abbey Crombie, chain whip, and BB tool
Wera Hex Plus allen keys
Bonhaus T-handle allens
15mm Campy PB Wrench
CDI preset torque wrenches (4 and 5 nM)
Dremel tool with cutoff wheel (cutting housing square)
Small pick for opening cable liners and removing bearing seals
Pin point lubricant bottles (something like 50 cents each on Amazon)
Knipex pliers
Wheels Manufacturing bearing press kit
Old grease guard grease gun
Be careful - itâs a slippery slope!
Iâm only two tools short of a full bike shop imo - I canât do crown race setting or headset press properly, Iâve bodged it on my road bikes. Iâm a Campag guy so everything is expensive, but Iâd say that over two years Iâve probably broke even if Iâd used a bike shop insteadâŚnot counting the hundreds of hours of fun/frustration.
It is good to know how everything on your bike works, because you built it, but you could save yourself a lot of brain ache by just paying up for bike maintenance.
I am trying to put together a tool list that contains everything needed for someone who kind of knows his way around a bike to do all servicing. Basically, I donât ever want to have to go to a bike shop for servicing. I have done basic things such as gear indexing and re-cabling, but I want to be able to do more. (I am talking replacing bottom bracket, wheel truing, etc.) Currently, I am limited by my equipment. I believe this is an endeavor that will interest others in the community.
Can you guys help me put this together? Specific brand/model recommendations are welcome.
List So Far
bicycle work stand
set of Allen keys
screwdrivers
pedal spanner
cable cutters
chain tool
master link pliers
bottom bracket tools
- What do I need here?
chain whip
- Any other cassette tools?
spoke nipple
wheel truing stand
tire leavers
track pump
torque wrench
- What sizes are really necessary?
= in possesion
= missing
Thanks for your time. Feel free to recommend any additions or subtractions.
If you guys want to know what specific tools I have, I can share those as well.
I hate chain whips. This device whips the llamas ass: https://www.amazon.com/Pedros-142722-Vise-Whip/dp/B001Q270CC
Love it. Love it. Love it.
@tkent, I moved your post under an existing one that had lots of posts and suggestions. Check them out along with any new stuff that people share.
Bottom bracket will depend on just what BB you have, just about every 'standard" needs a different tool.
For cassette removal a chain whip and a cassette removal tool plus an adjustable spanner to hold it.
Spoke nipple: not really needed plus a lot of multi-tools have the appropriate slots somewhere in their arsenal.
Wheel truing stand - for simple jobs turn the bike upside down and use a pencil held against the forks or stays.
Torque wrench: very much a nice to have but if youâve a carbon frame it might be a bit more essential. You need to get one that has a small range around the usual values you are likely to need, so 2nm - 20nm rather than 2nm - 200nm.
If you have disk brakes then a set of Torx keys.
Some good info from other sources:
Not that you need those specific kits, but it is a comprehensive list of the tools that you should at least consider, if you build your own kit.
Possibly the most under-rated tool in the box:
Bent or misaligned derailleur hangers are one of the most commonly overlooked issues that cause poor shifting. Itâs less of a problem now with through axles and machined derailleur hangers, but itâs still not unusual for brand new bikes with brand new hangers to be poorly aligned. Many shops are too lazy to do a 2 minute check. There is just no way to eye-ball the alignment on a RD hanger, youâve got to have a tool.
Iâve looked at some of these but the problem is that I already have a number of tools. I donât want to double up, as it seems like a waste.
Thanks for the suggestion.
Didnât realize this thread existed. Thanks.
Great idea.
A torque wrench is pretty high up on my list. I have this adjustable t-handled one that goes up to 8 Nm, so it will cover all but a few bolts (crankarms, certain seat clamps, and perhaps a RD fixing bolt are the ones that come to mind).
A small-ish adjustable wrench and some channel locks are handy general purpose tools too. As is denatured alcohol (particularly if youâre going to use the aforementioned wrench to true a disc brake rotor).
Oh, and a little grease gun, like so.
I use an old syringe. Itâs perfect to do the grease replacement in Speedplay pedals.
I have 3 toolboxes - a generic fix-everything-in-my-daughtersâ-apartments one, a bike one, and a ski tuning one. Everything I need fits in the second one, except the torque wrench and a box wrench set.
- Right, and thatâs exactly why I included this commentâŚ
Iâve assembled my toolkit over several years as Iâve needed tools for specific jobs. No need to buy something before you need it. And when you buy it at point of need, youâre more likely to get the right thing - vs buy a tool, have it sit on the shelf for 2 years, and then when you first go to use it, you find itâs the wrong tool.
There are some basic tools that you need pretty much right away - torque wrench, hex bits, torx bits. Some of the more specialized stuff you wonât need for a while Eg bottom bracket tool.
Also, a little creativity allows you to use a tool you already have vs buying a new one. Eg I donât have a master link pliers, I use a needle nose pliers and it works fine.
Different BB standards require different tools. Your next bike will likely require a different tool. On this basis, if your BB requires replacement, that may be one of the very few tasks you leave to your LBS rather than buying a tool that may only ever be used once.
Unless perhaps you are talking about tools for BSA threaded BBâs. That standard seems pretty durable, and one that several manufacturers are actually reverting to.
PRO BIKE TOOL 1/4 Inch Drive Click Torque Wrench Set â 2 to 20 Nm â Bicycle Maintenance Kit for Road & Mountain Bikes - Includes Allen & Torx Sockets, Extension Bar & Storage Box https://www.amazon.com/dp/B07JKJTDWC/ref=cm_sw_r_cp_api_fabt1_BKsVFbAMGCZYJ
Anyone using this? After stripping a bolt on my proprietary seatpost I think itâs a good time to invest in a torque wrench.
Also, got white lithium grease for said seatpost where the metal cups meet the carbon, I know this stuff is also good to use on headsets and such, can it be used on bolt threads too to prevent seizing?
