I don’t really have anywhere to do a good 20 min sweet spot workout near me, roads are way too hilly/lumpy and the longest climb I have ready access to is about 16 mins long.
Sooo…as sweet spot workouts are really about accumulated time at sweet spot effort…surely there is nothing wrong with something like the following:
3 blocks of 2 x 10 min sweet spot - descend ( I guess about 2-3 mins ) with about 10 mins rest.
There are similar workouts in the library so I guess it should be ok right?
Antelope is with larger recovery valleys between each set. Antelope +3 is kind of the same but 6x 10 mins with 2.5 min recoveries between each.
My theory is that they are all so similar that it is really the same outcome in a slightly different form?
Antelope +3 is what i was thinking of. I just did that one here recently. . i do 90% of my rides outside and you just have to accommodate the best you can. I think Chad said a few weeks ago if your outside then 90% accuracy is pretty good.
Yesterday the worst part of outside riding happened. i finished my vo2 inverse at the bottom of a 15-18% grade hill
You are mitigating everything coach Chad discusses in the podcast. I am paraphrasing but he said something along the lines of sweet spot workouts being more than fine as long accumulated time in zone is achieved.
You response seems to go into great length wanting to say ‘its not exactly the workout as layed out in the plan but it is still ok’ while using an (to say the least) extreme comparison. I thank you for pointing out the small nuances and their probably inconsequential impact on anyone not trying to eek out .005% marginal gain.
what plan are you following? At least in sweet spot base, there is a weekly progression to increase time in zone. That is a combination of longer intervals, and reducing time between intervals. Something to consider.
Personally when I climb they tend to be 30 minutes or longer, so I like to take sweet spot intervals out to 30 or 40 or 50 minutes. But I’ve got a 50 minute stretch of flat road into a headwind, so its a lot easier for me to dial-in the length of each interval.
