I finally got the Rouvy app downloaded for calibration (which I will mess with tonight), is there a difference between calibrating with TR vs Rouvy? I have always just used TR
I hadnāt thought of that. Pause TR, open Rouvey, calibrate!
I would do the calibration through Rouvy. It doesnāt take that long. I was told by someone at Saris/Cycleops that as long as you donāt move the Hammer you really shouldnāt have to re-calibrate it. He recommended doing it maybe once a month or so. I probably do mine every two to three weeks.
Very interesting conversation with Cyclops, evidently the TR calibration is useless with this smart trainer. This seems to be a common problem and he was even frustrated at TR for their software not being able to āplayā well with their product. I really donāt mind the two step process to training (ie calibration set up AND logging on to TR separately) as long as it works. I guess we will see this evening.
Bottom line: Always use Rouvy for calibration and not TR.
This is correct. Same with the Magnus. I just take it for what it is. I have to calibrate through Rouvy and move on and then I chalk it up to first world problems. If thatās the worst part of my day Iāve got it pretty good.
Can someone share the step by step instructions to calibrate with Rouvy?
I seem to struggle with the process.
- Open Rouvy App
- Go to FREE RIDE
- If you have connected to Rouvy in the past your trainer should be recognized and CONNECTED. If you this is your first time you have to go through SELECT TRAINER process.
- CALIBRATE button is located under trainer name.
- Follow instructions to calibrate. Pedal to 19-23mph for duration of time requested by app. 20 seconds. But it generally takes roughly 25 or so.
- Stop pedaling when it tells you to stop pedaling.
- You are now clear and ready for takeoff to ride on TRAINERROAD
Not to bad from memory hey?
https://support.rouvy.com/hc/en-us/articles/115004291089--How-do-I-Calibrate-the-Trainer- sent from Cycleops rep
Much appreciated, thanks!
It worked!!! It worked!!! I was able to sneak home at lunch to calibrate with Rouvy and did a quicky workout with intervals and smooth as can be and normal cadence of 90ish. HAPPY HAPPY HAPPY.
Calibrated with Rouvey this morning. Seemed to work, no issues spinning out after the Sprint intervals in disaster half anyway.
I have a Hammer and no issues at all with any zones. I calibrate it weekly. Works excellent and has been rock solid for the last year.
Thank you all so much for this thread. Iām considering a hammer and was a little worried about it and was going to pay a couple hundred more for a tacx neo. Ill grab the hammer. I also phoned cycleops and they say they are going to have a new update for the hammer shortly.
Thank you so much for this info. I picked up my h2 from REI finally. I spent an hour trying to calibrate it. Searched the net and YouTube and then remembered this thread.
So simple when someone takes the time to post it and when you know where to find it.
Did my first ride with it here at the hotel and am quite surprised how quiet it is. Iām running small front ring and middle rear.
Iām so looking forward to returning the clicker core.
I also think my ftp might go up as Iāve gotten used to the extra effort the clicker required to move(at least im hoping thatās the case).
Thank you again!
I think itās an amazing value at $800.00
Thatās awesome. It really is a great trainer. Happy riding.
So I have a question about sprinting. Basically what is the best practice. I followed the workout text and then switched to big ring and hammered it for the sprint. The problem is that the flywheel had so much speed at the end I couldnāt keep up and tr paused after the sprint because it thought I was not working. I had to wait until the flywheel slowed down enough to where I could pedal and tr recognized it.
I normally ride in the 34 front and middle rear. What is the best way to sprint? I really have no experience sprinting on a trainer as Iāve been waiting to have a hernia fixed and could not ride out of the saddle or do sprints. Itās was fixed 3 weeks ago so now Iām experimenting.
Thanks for the help!
I find it a bit ironic/odd. They have the one device that doesnāt work like other devices and TR is at fault? Especially since Zwift was/is having a problem with it as well. Maybe they need to think about making their product compliant to match the rest of the trainer world.
Could you please expand on this?
I am at a loss. The problem with zwift as far as I know is that it would overheat on long climbs. Supposedly fixed with firmware and I have not seen mentions of it in a long time. I donāt see how trainer road has anything to do with this. You need to use rouvy app to calibrate it. Yes its dumb, but it works. That has absolutely nothing at all to do with trainer road.
As for compliance I think it complies quite well. Especially when you compare it to the 4 week life span of a kickr core or kickr 18 (slight overkill there but Iām still pissed about my core!). Id rather have to calibrate with rouvy than break a new trainer every 6 weeks like a lot of people have and go through 6 or 8 of them on the way to get a working kickr. Whats going to happen to these people when warranty runs out? Its not like their warranty is being extended every time they get a new trainer!
As for tacx the neoās would be amazing but are out of my price range. As for the flux neither GpLama nor DCrainmalker has completed a full review of them because they just have to many problems. Ray is waiting for tacx to fix the issues before he releases his review and hes been waiting well over 6 weeks. As for Shane he will not allow any trainers into the Lama Cave that start with F*** (hintā¦flux).
Id really appreciate more information as I am a new H2 owner and your comments have me wondering about my purchase and something I might have missed.
I calibrate my hammer every month or two. I donāt move it around and take all my power readings from my Quarq, so I donāt think I have to calibrate it often. Itās just controlled resistance for me.
Regardless of what smart trainer or other device I may have, I would always use the manufactures chosen calibration method. I would never use a third party to calibrate any device. I suppose itās done by others for convenience, but I would always stick with the manufactures recommended way.
Reference overheating, in the year Iāve had the H1 and the number of successful hard climbs up Alpe du Zwift, Iāve never experienced any over heating whilst grinding away in the low rpms, so I wouldnāt worry with the improved H2.
Reference the fly wheel spinning out at the end of a sprint/high wattage interval. Others have solutions by switching to resistance mode, it youāre stopping in ERG mode like myself I have got to the point of knowing when the resistance drops and just before that point I stop my efforts on the pedals, as you get used to your trainer and its little Intricacies you do adapt. Iāve yet to find a workout I canāt perform well in ERG mode.
Can see myself buying another Hammer when that time comes around again. This is one solid dependable unit, might require a belt change in the future but fingers crossed itāll last until the H3 or H4 comes out!
Thank you very much for your lengthy and detailed response. As Iām still recovering from surgery I should be taking it easy on the sprints anyways. Iāll pay more attention and learn how to use it properly. Iām really happy with it so far. It is a little noisier than the core but then the core only really lasted 3 weeks lol.
