I am training for my first Leadville 100MTB this August. I was wondering if there is any information out there in regard to how watts/kg relates to finishing time? In other words what kind of watts/kg does it take just to finish sub 12 hour? Sub 11? Sub 10? Sub 9?..and so forth. A chart would be awesome! I know there is much more to that race than just your FTP…endurance, nutrition, coral position etc. But it would be nice to have an idea of a time frame to set a reasonable goal. I currently at a 3.0 watt/kg with hopes of a 3.5 come race day. Thanks!
I’d have to go back and dig through my data to confirm, but rough guidelines for a sea level athlete
- 4.5w/kg: Sub 9 if you have a solid day, Sub 8 on a perfect day
- 4 w/kg: Sub 10 if you have a solid day, Sub 9 on a perfect day
- 3.5w/kg: Sub 11 if you have a solid day, Sub 10 on a perfect day
- 3w/kg: Sub 12 if you have a solid day, Sub 11 on a perfect day
I was around 4 watt/kg at sea level (maybe 4.1) and did a 8:53 (or something like that).
That’s with a blowup. I think you could take 10 minutes off that time if you had better handling skills.
I was super optimized though with equipment and nutrition (unless I wasn’t ).
It’s interesting how close you and I were for the first half of the course. Within 1 minute over 4 and a half hours!
(I was 4w/kg on race day)
Thanks you all! This is all good information. My original goal was just to finish the darn race, but thanks to TR my FTP keeps on going up exponentially. If I can get up to 3.5 watts/kg I may have to change my goal to sub 11 or 10 1/2. Im also a Leadville native, so that might help. I have another question about Leadville, but I submitted it to the TR team so I’ll wait to see if Nate answers it on the next Podcast
I’m right here . Ask away!
If you’re currently living in Leadville you have a big advantage being acclimatized to 10k feet. A 3.0 W/kg in Leadville is about the same as someone who has a 3.75W/kg at sea level and travels to Leadville for the race (no/little acclimatization).
I’m 3.25 W/kg at 7k feet and rode it in 9:38. 3.25 W/kg is about 3.0 at 10k feet - so you’d be similar to me. I think a sub 10 is possible for you if you have a good day - right pacing, hydration and nutrition; no cramps, mechanicals or crashes.
Ride the Silver Rush as a prep race. It will help you dial in your equipment, hydration, nutrition - and you may also be able to improve you’re corral placement into purple or maybe green. And it’s a good benchmark to estimate what your LT100 finishing time might be.
I did the LT100MTB at around 3.5 this year and finished in 10:39. Everything went perfect for me. My original goal was to finish under 12, but as I got close to the event, I knew my fitness was really good and adjusted my goal to sub 11.
Thank! Its great to have an idea of what the time frame will be for me. Time to put in the work, and get my ftp up. I think sub 11 is definitely doable
Well my question I submitted to the team was this. My sweet spot training followed by sustained power build followed by the century plan will end in April. Should I continue to train with TR after that leading up to the race in August? Or should I spend most if not all of my time on the MTB100 course? Riding the course will familiarize me with the course as well as develop technical skills, but training on the trainer will ensure that I train at threshold which in turn will yield a higher ftp. I do not have a power meter to train outdoors.
As you probably know, the course is not technical. The power line and sugar loaf descent had me hitting the brakes, but I suck.
I don’t think this is an either or thing. I’d do Sunday aerobic rides on course and do the rest on the trainer. I think you’d get the best mix of both worlds with that.
I started a similar topic on the Leadville 100 MTB Participants group on Facebook, where a members have been sharing some very interesting data on qualifying event times and their LT100MTB finish times. You can find it here: Leadville 100 MTB Participants | Facebook
@Nate_Pearson, wanted to tag you on this, as you might find it interesting. Feel free to ping me, if you would like the backup data–could make a very interesting podcast episode!
I have run some analysis on how qualifying event times have translated for athletes that went on to attempt the LT100MTB. The “Over” column indicates the count of athletes that finished the LT100MTB in a time greater than their corral position might have indicated, and “Under” means they came in under the cut-off time for that corral.
As far as getting a good corral position, Wilmington Whiteface looks to be the best bet, followed by the Barn Burner. See the analysis below–I think it’s very illuminating:
Austin Rattler | |||||||
Corral | Avg Austin time | Count | Avg LT100 Time | Count | Avg Multiplier | Over | Under |
Gold | n/a | 0 | n/a | 0 | n/a | n/a | n/a |
Silver | n/a | 0 | n/a | 0 | n/a | n/a | n/a |
Red | 04:29:36 | 1 | 08:20:10 | 1 | 1.86x | 0 | 1 |
Green | 04:46:35 | 9 | 08:05:09 | 9 | 1.69x | 0 | 9 |
Purple | 05:15:13 | 11 | 09:04:55 | 10 | 1.74x | 0 | 10 |
Orange | 06:01:48 | 46 | 10:09:26 | 46 | 1.69x | 11 | 35 |
Blue | 06:46:24 | 22 | 10:53:11 | 18 | 1.61x | 1 | 17 |
White | 07:22:15 | 23 | 11:31:07 | 18 | 1.57x | 18 | 0 |
Overall | 06:15:38 | 112 | 10:13:12 | 102 | 1.66x | 30 | 72 |
Willmington Whiteface 100k | |||||||
Corral | Avg Whiteface Time | Count | Avg LT100 Time | Count | Avg Multiplier | Over | Under |
Silver | 04:37:18 | 13 | 08:50:16 | 13 | 1.91x | 10 | 3 |
Red | 04:54:46 | 14 | 09:38:40 | 13 | 1.96x | 13 | 0 |
Green | 05:16:48 | 15 | 10:33:08 | 15 | 2.00x | 14 | 1 |
Purple | 05:44:58 | 20 | 11:20:45 | 17 | 1.97x | 15 | 2 |
Orange | 06:24:00 | 17 | 11:25:49 | 10 | 1.82x | 8 | 2 |
Blue | 07:22:35 | 6 | 12:34:34 | 2 | 1.71x | 1 | 1 |
White | 08:53:12 | 1 | n/a | 0 | n/a | n/a | n/a |
Overall | 05:38:22 | 86 | 10:26:28 | 70 | 1.93x | 61 | 9 |
Lutsen 99er | |||||||
Corral | Avg Lusten Time | Count | Avg LT100 Time | Count | Avg Multiplier | Over | Under |
Gold | 05:21:01 | 1 | n/a | 0 | n/a | n/a | n/a |
Silver | 05:35:53 | 3 | 08:16:26 | 2 | 1.47x | 1 | 1 |
Red | 05:48:28 | 5 | 08:37:27 | 5 | 1.49x | 3 | 2 |
Green | 06:05:22 | 3 | 09:57:09 | 3 | 1.63x | 3 | 0 |
Purple | 06:38:07 | 36 | 10:21:37 | 33 | 1.56x | 21 | 12 |
Orange | 07:16:52 | 15 | 10:58:00 | 14 | 1.51x | 7 | 7 |
Blue | 08:04:35 | 25 | 11:31:21 | 14 | 1.46x | 4 | 10 |
White | 09:12:19 | 2 | n/a | 0 | n/a | n/a | n/a |
Overall | 07:05:15 | 90 | 10:30:39 | 71 | 1.52x | 39 | 32 |
Silver Rush 50 Mile | |||||||
Corral | Avg Silver Rush Time | Count | Avg LT100 Time | Count | Avg Multiplier | Over | Under |
Gold | 04:05:32 | 6 | 07:18:48 | 5 | 1.79x | 0 | 5 |
Silver | 04:20:29 | 6 | 07:35:50 | 5 | 1.75x | 0 | 5 |
Red | 04:55:55 | 50 | 08:41:13 | 49 | 1.76x | 29 | 20 |
Green | 05:30:31 | 57 | 09:39:35 | 56 | 1.75x | 46 | 10 |
Purple | 06:08:48 | 71 | 10:35:42 | 67 | 1.73x | 53 | 14 |
Orange | 06:52:45 | 61 | 11:29:17 | 53 | 1.67x | 41 | 12 |
Blue | 07:36:41 | 29 | 12:00:17 | 25 | 1.58x | 13 | 12 |
White | 08:11:41 | 11 | 12:07:08 | 2 | 1.49x | 2 | 0 |
Overall | 06:06:37 | 291 | 10:14:43 | 262 | 1.71x | 184 | 78 |
Tahoe Trail 100k | |||||||
Corral | Avg Tahoe Time | Count | Avg LT100 Time | Count | Avg Multiplier | Over | Under |
Gold | 03:58:50 | 1 | 07:14:39 | 1 | 1.82x | 0 | 1 |
Silver | 04:30:22 | 4 | 07:23:37 | 3 | 1.62x | 0 | 3 |
Red | 05:00:40 | 19 | 08:28:57 | 18 | 1.69x | 9 | 9 |
Green | 05:37:31 | 33 | 09:36:10 | 31 | 1.71x | 25 | 6 |
Purple | 06:20:46 | 23 | 10:49:14 | 23 | 1.71x | 18 | 5 |
Orange | 07:04:56 | 10 | 11:48:46 | 9 | 1.66x | 8 | 1 |
Blue | 08:03:27 | 2 | 12:32:40 | 2 | 1.56x | 2 | 0 |
White | 08:56:49 | 1 | n/a | 0 | n/a | n/a | n/a |
Overall | 05:51:25 | 93 | 09:53:09 | 87 | 1.69x | 62 | 25 |
Leadville Stage Race | |||||||
Corral | Avg Leadville Stage Time | Count | Avg LT100 Time | Count | Avg Multiplier | Over | Under |
Gold | 06:34:52 | 9 | 07:17:10 | 9 | 1.11x | 2 | 7 |
Silver | 07:16:51 | 11 | 08:14:53 | 11 | 1.13x | 6 | 5 |
Red | 07:46:59 | 14 | 09:22:31 | 13 | 1.20x | 12 | 1 |
Green | 08:14:58 | 23 | 09:22:11 | 22 | 1.14x | 15 | 7 |
Purple | 09:01:38 | 25 | 10:23:27 | 22 | 1.16x | 14 | 8 |
Orange | 09:43:39 | 18 | 10:57:39 | 18 | 1.13x | 8 | 10 |
Blue | 10:18:40 | 13 | 11:49:15 | 8 | 1.15x | 3 | 5 |
White | 11:18:09 | 26 | 11:56:06 | 14 | 1.09x | 14 | 0 |
Overall | 09:06:47 | 139 | 10:00:57 | 117 | 1.14x | 74 | 43 |
Barn Burner 104 Mile | |||||||
Corral | Avg BarnBurner Time | Count | Avg LT100 Time | Count | Avg Multiplier | Over | Under |
Gold | 05:51:21 | 1 | 06:39:31 | 1 | 1.14x | 0 | 1 |
Silver | 06:49:22 | 1 | 08:15:06 | 1 | 1.21x | 1 | 0 |
Red | 07:18:14 | 5 | 09:02:14 | 5 | 1.24x | 5 | 0 |
Green | 07:47:12 | 7 | 10:36:19 | 6 | 1.36x | 7 | 0 |
Purple | 08:17:39 | 12 | 10:23:11 | 10 | 1.26x | 10 | 2 |
Orange | 08:44:48 | 8 | 11:03:08 | 6 | 1.27x | 6 | 2 |
Blue | 09:37:38 | 1 | 12:10:51 | 1 | 1.27x | 1 | 0 |
White | n/a | n/a | n/a | n/a | n/a | n/a | n/a |
Overall | 08:04:52 | 35 | 10:12:10 | 30 | 1.27x | 30 | 5 |
I just got an email that the austin rattler has a change of venue. So the times go out the window with it
Nice work!
If I’m interpreting this correctly, this shows that most of the qualifiers (Austin being the exception) will tend to get you into a corral that is above your abilities.
I thought that based on my Silver Rush qualifier. I got into the green corral, which in theory would have meant I could do a sub nine. I did 9:38.
Correct; i.e. green corral at SR would imply a <9:00 finish at the LT100MTB; to get into the green corral by using your LT100MTB time the following year, you would need to have come in under 9:00.
I’m working on a way to re-cut the analysis to make that a little more intuitive…
Yes; this past year–2018 results.
