Damn some really nice setups. Mine is fairly simple. I am in my shed, using my BBQ as a stand; having a brick as wheel support and training on a dumb trainer
If i need a fan, i just open the doors
Love your sense of humor. Had tears in my eyes.
Did you listen to the latest podcast? Aging athletes need more protein.
I have been playing around with a design for a rolling stand to build but seeing your post inspired me to look into this with a folding shelf bracket. That way it is out of the way when not in use. Thank you. What model bracket did you use?
Seriously look into a stronger fan. Or at least an additional fan. That little one will be ok on your face, but the rest of you will want something soon.
What could be better? Well, for starters, I’d like a giant 60" monitor!
Luckily I have a nice temp controlled space I’m set up in, but yeah, a fan addition/upgrade is on the radar.
I used a 12" (30cm) brass hinge. It comes with all 12 screws, however I used six 1 1/2" (~40mm) deck screws to affix the hinge to the wall.
EDIT: The shelf is reinforced with a parachute cord suspension system using screw in eyelets. To keep it from falling down when stowed I used a spring loaded gate latch
Thank you. I am thinking about using a folding shelf system to do something similar.
Can you share the website for that product please?
Yes, that’s the one: https://purelycustomfit.com/product/wheel-riser/ It cost less than the wahoo climber. Climbing Simulator for Indoor Bike Trainer | KICKR CLIMB | Wahoo Fitness, but you have to get off your bike and adjust it manually. I have a portable electric drill to quickly adjust it.
Dude–it works for you and better to be frugal!
that BMC is beautiful
Holy s#$&, that’s beautiful.
Yes! We need need more track & fixed gear representation here.
Are those for sound proofing your walls? I used to have a wahoo kickr but got rid of it because the noise it made resulted in permanent hearing damage–tinnitus.
I think this would be better in theory than in practice. That is unless your bike is set-up way far back from it.
Not a problem for me. I wear a sweat band and the fan is blowing so hard and evaporating sweat so fast that it’s not a problem. They do get sweaty, for sure, just not so bad to where i can’t wear them.
I really need to get a set of bluetooth ear buds…just not sure what to get. I absolutely abhor my Apple wired ear buds…have to be the worse possible designed ear buds in history.
