According to my missus, I sometimes snore. I reckon she’s just a light sleeper Anyway, nasal strips and a turbine have helped in that department.
I tried both methods when riding and they also gave me a noticeable improvement to airflow. Only downsides I found:
A) nose strips tend not to stay put for the entire ride
B) people think you have a nose piercing with the turbine
C) some folks may think you’re taking things a bit too seriously with either method (marginal gains etc)
I started using Breathe Right strips about a month ago and now I will not train without one.
Sweat becomes a problem about 20-30 minutes in, so I’ve found that I need to apply the strip, and then put a long strip of band-aid type tape over it to keep it from peeling up. It may look stupid, but it has a noticeable positive effect on airflow through my weird nose.
Rhinomed is the company. Turbine is the ‘sporty’ version of the nasal dialator, whilst ‘mute’ is the snoring version. I’m pretty certain they are more of less the same thing, just different colour and branding
I’m a bit of a skeptic when it comes to these strips.
If you think how big your mouth is compared to your nostrils, you can get all the air you need through your mouth.
But that may just be me
They still exist? This is a through back to the late 90s for me, heavily used in Rugby and Football for a few years before the the research into such products caught up with the marketing. Although, never heard about using them to help with sleep, is this the marketing relaunch… lol. Thanks for the thread, helped me reminisce back to 20 years ago.
Maybe there is something in it regarding sleep but I doubt it. As far as I’m aware snoring generally is a restriction further along nasal passage and airways. Flaring out you nostrils with a strip shouldn’t help as that generally this isn’t where the restriction is, as found with a study for performance improvements back in the 90’s. Regarding sleep could be wrong though.
That’s the one Turbine, as I said for a TT its great, RR not so for me. When your on the trainer practice with it in, as it is uncomfortable and the more you get used to it, its still uncomfortable. Just less so.
It’s not a great idea, firstly you don’t need the volume of air you can take in via your mouth, but secondly the nose moistens and warms the air that you breathe as well as remove particles in the air, so its far better for your lungs!!
that sounds a bit reassuring that it’s not just me.
My nose has a weird shape after quite a few years of rugby and a few broken noses. I certainly find that the strips open up one of my nostrils, and I think this is helping me breathe better at night so I am sleeping better. That should mean I am recovering better, every little helps!
I will give them a go training as well.
In a little bit more time spent online, I took the test provided by the British Snoring Association, and it recommended trying Nozovent, which are inserts that push outwards. Worth trying for sleeping I think for me.
I am not sure it would help anyone but I have got a weirdly broken nose (thanks to fun in rucks etc). I don’t think they would help anyone with a ‘normal’ nose, but I certainly noticed a difference in how much easier it was to breathe when I put. them on a night, which means my mouth can stay shut a bit more.
I used both (first the strips then a turbine) for about 2 years. I stopped after having turbinate reduction surgery and having my deviated septum fixed. Now I can breath as well through my nose as I could with the turbine in place.
Not sure if helped or not but it didn’t hurt. Felt like it helped some on higher allergy rides as well in terms of how much my nose could run before I was forced to breath through my mouth. One drawback is it makes it harder to blow snot rockets when needed. Although that’s mostly just a nuisance on solo rides.
Haven’t tried using them since the surgery though.
and in the week or so I have tried them it seems to be working really well.
The strips were bits of plastic that pulled the nostrils out, the Nozovent is a C shaped bit of soft plastic that pushes the nostrils out.
I haven’t tried them riding , but I certainly feel like they are helping me sleep.
Have you tried the turbine since having the surgery? I’m contemplating the surgery to fix my deviated septum, for allergy and airflow reasons, but a coworker of mine mentioned that he can still breathe better with the strip, even after his surgery. Wondering if this is a case-by-case thing?
The first consult I got on surgery said that he “couldn’t guarantee I would get noticeable improvements in airflow,” so I kind of tabled the matter for now.
Turbines on rides have been making a big difference so far, though.
