Here are some additional plan improvements! This time we tackled all of our Climbing Road Race plans.
How do I update a plan on the calendar to reflect these changes?
There are two types of changes: In place changes and workout changes. You don’t have to do anything for in place workout changes, they are automatically reflected on your calendar.
If you see something like this, Junction —> Junction -1 then that’s a workout change. To update those you have two choices:
- Remove the plan from your calendar and re-add it
- Find the specific workouts we changed and update those manually
Here’s what’s changed and why.
Climbing Road Race Low Volume
Week 2 - Tuesday - Huxley
Change: The demands of these intervals were toned down only slightly. Also, the recovery between each set of intervals grew from 4 minutes to 5 to allow for a little extra recovery between each trio of attacking intervals.
Reason: This was done with the intention of keeping the challenge high but making each repeat more manageable, especially the final interval in each set.
Week 5 - Tuesday - Bradley
Change: The recoveries between intervals doubled from 2 minutes to 4.
Reason: This was to allow for more thorough recovery prior to each subsequent interval.
Week 6 - Thursday - Kern —> Kern -1
Old - Kern
New - Kern -1
Change: This is a mildly toned down version of Kern with the same short recoveries but slightly shortened work intervals.
Reason: This was done to keep it challenging while also having quality intervals, especially in the last set. Also means the original version is still available in its unaltered state.
Week 6 - Saturday - Sonora +2
Change: The first 2 recoveries were increased from 3 to 4 minutes.
Reason: To keep riders a little fresher earlier in the workout and give them a better chance of finishing strongly with higher-quality, later intervals.
Week 7 - Tuesday - Basin -4
Change: Since -4 is intended to be a taper version of Basin, the intervals dropped 1 minute in duration and the recoveries rose by 60-90 seconds.
Reason: This keeps the intensity where it needs to be but cuts back the duration enough to stay in line with the goals of taper workouts.
Week 8 - Tuesday - Basin -5
Change: Since -5 is intended to be a taper version of Basin, the intervals dropped 1 minute in duration and the recoveries rose by 60-90 seconds.
Climbing Road Race Mid Volume
Week 1 - Thursday - Mount Deborah +1
Change: An extra minute of recovery was added between every pair of intervals.
Reason: An extra minute of recovery has proven to be highly productive with these shorter, supra-Threshold repeats.
Week 2 - Tuesday - Huxley +1
Week 3 - Tuesday - Gould +1
Change: The final 4 intervals in this workout saw the most frequent failures and were toned down slightly.
Reason: This was done in order to keep riders productive all the way through the very last interval.
Week 5 - Tuesday - Bradley +1
Change: A slight reduction in the intensity of each Threshold valley dropped them from 95-99% FTP down to 92-96% FTP for a 3% reduction.
Reason: This was aimed at making things only minimally more manageable without changing the nature of the workout nor its intended outcomes.
Week 5 - Thursday - Diamond +1
Change: All of the recovery valleys are now legitimate recovery valleys.
Reason: The previously shorter-duration, higher-intensity Endurance valleys were a little too demanding and were detracting from the quality of each remaining set of bridging efforts.
Week 6 - Tuesday - Basin +1
Change: The recovery valleys each gained an extra minute.
Reason: To give riders an extra bit of active rest keeping them fresh for quality last intervals.
Week 6 - Thursday - Kern +2
Change: The very short, 30-second recoveries with each set of repeats grew to 45 seconds.
Reason: This extra 15 seconds of recovery will make the last few intervals more tolerable but still highly aerobically demanding.
Week 7 - Thursday - Kern —> Kern -1
Old - Kern
New - Kern -1
Week 8 - Tuesday - Basin -4
Climbing Road Race High Volume
Week 1 - Saturday - North Twin +4
Change: The recovery valleys were all reduced to the standard 40% FTP. Additionally, all interval ramps were removed allowing the recovery valleys to grow from 3 minutes to 4.
Reason: The so-called “recovery” valleys between the Tempo intervals weren’t allowing enough of a break to keep riders strong throughout the workout.
Week 3 - Saturday - Roan High +4
Change: The recoveries were all reduced to the standard 40% FTP. Additionally, all interval ramps were removed allowing the recovery valleys to grow from 1 minute to 2.
Week 5 - Saturday - Sierra +5
Change: The recovery valleys were lightly adjusted from 50% FTP down to 40-45%.
Reason: The lower recover valleys should translate to high quality work intervals for the entirety of the workout.
Reason: This has been proving to make the more brutal interval workouts more productive.
Week 6 - Saturday - Sonora +6
Change: First, the pre-interval ramps were removed in favor of more recovery which partially allowed the valleys to grow from 2 minutes to 3. Then, the Endurance block shrunk from 50 minutes to 40.
Reason: The increased recovery between work intervals should help keep riders from burning out on the final endurance stretch.
Old - Kern
New - Kern -1
