Podcast show notes
#1
Request for the podcast team,
In the podcast show notes would you be able to put the time that each different topic starts?
I only listen to podcasts while driving, and don’t have time to listen to the full podcast, so it’d be handy to be able to start the podcast at a certain point when I start my commute (that way I can skip the MTB/CX stuff :slight_smile:).
Here’s an example of the show notes that are visible in Podcast Addict (I believe these are pulled in from iTunes):
If you’d be able to put the time in brackets after each listed topic it’d make it really quick to skip to the stuff I’m interested in.
#2
It’s possible to add chapters to podcasts so that you can easily skip forwards or backwards to the correct time stamps.
Mike
#3
Good call @themagicspanner, it’d be ideal if TR could split the podcast into chapters.
As a workaround I’ve just taken a look in Podcast Addict and they’ve got “Bookmarks” you can add to. If TR could add the times in the show notes it’d make it real quick to build up the bookmarks.
