Ramp Test Tips & Tricks
ramp-test
ftp-testing
#106
Not a direct answer for the Ramp Test, but common options for regular races.
#107
Does it matter when you stop the ramp test or does it just look for the highest 1 minute power across the workout?
The reason I ask is because I did a “test” ramp test ahead of my first real one tomorrow,
Step 14 was 390 for me, I hit 394, I failed on step 15 which was 408, I did however do a couple of bursts after but didn’t stop the workout until step 18. My feeling is it doesn’t matter but I was thinking it would automatically stop it once it detected I had failed.
#108
The FTP calculation is bassed on the highest 1-minute power in the test.
It is instructed that the test should be done completely in the saddle, and you shouldn’t sprint in the end. Just spin as long as you can hit the targets in the saddle, and end when you fail on the target power, or just cannot spin the pedals anymore.
At the end of the test, every second you survive, will count.
#109
I love how it say’s you shouldn’t sprint at the end, if you’ve done it properly sprinting will be the last thing on your mind. I did it fully seated then began my recovery when I cracked.
#110
The fastest way to force the Ramp into the recovery phase is to stop pedaling or backpedal when you pop.
Maintaining forward pedaling will keep the test running, even if it is lower than your peak.
#111
I believe this depends if you have auto pause on or not. I generally don’t as a rule and so when you stop pedalling the test just keeps on going until you can muster the coordination to press the stop button.
#112
That is probably true. I use autopause.
#113
Interesting, I might have to turn it on for my ramp test tonight so I don’t get sweat all over my mouse…
#114
Here’s how to calculate your new FTP by hand:
Two parts…
1.) Take the power of the last full minute you completed
2.) Take the difference between the power of any partial interval you did less the power of the last full minute you completed & multiply that difference by the quotient of the seconds you remained on power in your final, partial interval & the number of seconds in a full interval.
Add 1.) to 2.).
Multiply by 0.75.
So if you did a full minute interval at 250 watts then failed 40 seconds into the very next interval at 265 watts your new ‘FTP’ would be:
(250 + (265 - 250)*(40/60)) * 0.75 or 195watts
This is the same method, but with different interval lengths and step size, as used in the Hawley/Noakes paper.
So if you want a 300W ‘FTP’…all you gotta do is ramp up to 400W and hold it for a minute. :wink:
#115
This is actually:
[250*(20/60) + 265*(40/60)]*0.75,
that is simply 0.75 times the average power of the last minute before failure. In other words, 0.75 times your best one minute power.
#116
Mixing a few threads here: Ramp test, Gearing does matter, Death Spiral
Did my first ramp test yesterday (coming from the 8 min world) and overall I think this will be a better way to go for me (pacing over 8 min ain’t no easy thing) - Thanks Nate et al. for more options.
Despite my overall optimism, my 1st test came to a very abrupt and unbecoming end.
  • I’ve got a Tacx Neo, and like others, train in a low gear (36 x 18’ish) to minimize noise
  • My cadence is usually 90-95
  • When I hit the 19 min mark and wattage stepped up, everything came to halt (and I was rolling just fine before that, although suffering of course). My impression is that I stuttered just enough to initiate a death spiral , and the stutter/pause almost instantly became pedaling in concrete.
Can anyone comment
  • Is this a “thing” ? Or is it just my one-off experience?
  • I’m thinking I should try both increasing my inertia by going for a much bigger gear and perhaps getting the cadence up to 110 rpm when I hit the 18:55 and 19:55 marks, etc. Although my concern is that I might be “gaming” my own FTP by cherry-picking a gear I don’t typically train in (I guess the push back is that since FTP tests are compared to FTP test, consistency is the key thing?)
Any input appreciated - Thanks !
-Mike
#117
I wish I had a Neo to test. But I’ve never touched one. Maybe someone with one can comment better.
Bit trying a bigger gear is a good test. I always suspect the virtual flywheel function on the Neo as a potential issue in cases like this. Ot depends entirely on the programming instead of real physics like a Kickr or similar trainer with a real flywheel.
I’d try to use your normal cadence range and only change gearing. (One variable swap is best for testing.)
#118
Bear in mind that 19:30 is the breakeven point. If you carry on past here you’ll see an FTP increase. That last 30 seconds after the 19 minute mark is going to be brutal if your FTP is set right
#119
I’ve experienced this during intervals. TR ramps up the power about 2 seconds early and sometimes will overshoot by quite a bit. If you keep your cadence constant, it almost feels like someone threw a big ball of mud into the trainer.
You can work around this by anticipating the power change (remember that TR still commands it 2 seconds early) and then briefly increase your cadence by 5-10 RPM. The increase in RPM will make it a lot easier and sometimes even leads to TR undershooting target power. It will go back to normal in a couple of seconds but you avoid that death trap.
#120
All - Huge thanks for the insights - Really helpful.
Tigloo - I think you nailed
  • As Pirnie said, during the 19th min I’m obviously reaching my limit, so I’m pretty fragile. Ordinarily when my trainer hits me with a step-up I’ve got the gas to deal with it (like in Sweet Spot stuff) - During the ramp test though, concrete in the trainer. A dead stop within a couple of seconds from the step-up.
  • Yep, I routinely get the 2-seconds early power hit (Neo controlled via Bluetooth iPhone, Not power-matching which I imagine would only increase the herky-jerky).
  • I did Monitor +1 today, and you can clearly see the “just another day in the office” power overshoots
  • I’ll play around with both cadence and gear choice - Thanks again.
Monitor_Overshoot
#121
 _deceiving. He tells us we’re doing better than most or even better than the team at times that would leave you with a reduced FTP if you stopped._
Yep same here.I freaked out when the message said that I had gone farther then Coach Chad and I didn’t want to “over do” my ftp. Lesson learned. Don’t read the messages during the ramp test.
#122
What am I doing wrong if I feel like I have blown up completely at the end of the ramp? Legs are toast, HR is 191 and my breathing is at full bore all at the same time.
#123
Nothing? If you feel like that at the end of the ramp you have done it as intended. I don’t think you should feel like you have more to give at the end
#124
Surely that means you have done it right though? :thinking:
#125
Hi
I have a Neo also i don’t have this issue but ride 50 x 18 ish. My cadence is similar . I make sure to keep an eye on when the ramp goes up ( the neo kicks in about a second early ) and prepare for a little more effort . Hope this helps your problem
