Recommend me a floor fan (UK)
Hi all
Anyone recommend me a floor fan? I’m in the U.K. oh, and I’m a tight bugger who doesn’t want to pay much, if I don’t need to…
I bought this http://amzn.eu/d/h2i4yJW via Amazon and it does a good job
I’ve got a Prem-I-Air one, also with an 18 inch fan. I’m sure I paid around £40 a few years ago maybe from Ebay.
I think there are a good number to choose from around that price point and I’m sure they’ll all be decent. Mine replaced one with a 12 inch fan and was significantly better.
I’ve got an aircon unit on wheels that I use. Was about £100 in the sales a few years back. Do train in my garage though, the outlet hose slides under part open garage door.
Major benefit of aircon is I don’t drop sweat everywhere.
I’m using a couple of HOneywell fans off Amazon - Were £26.99 each.
They do the job. Still sweat buckets, but I think of it as good heat training for summer :slight_smile:
Pop to Screwfix and pick up a 18-20" Floor Fan.
I have an 18" floorfan and 2 Honeywell HT900E (the small black fans often seen on tripods/zwift setups).
I see users often boast about the Honeywell’s being better than big floor fans because the flow is more focused and they usually end up with about 6 of the things. Absolute tripe. The flow is more focused but the volume of air they shift is pitiful if you run really hot like I do.
They are quiet though and when it’s cooler or the ride is less intense they’re a good substitute for when a floor fan, even on its lowest setting, is overkill.
Used this for the last 4 years still working as it did on day 1 link
+1 for Screwfix floor fan.
https://www.screwfix.com/p/18-floor-fan-220-240v/3939x
If £30 is too much just wait for them to have it on offer.
Worked well for me for the last 2 years.
Must be popular. Can’t find any stock near me!
Hi all. Thanks for the advice. I’ll pay a visit to my local screwfix. Sounds like a plan!
This works fine for me
I recommend getting one with a remote control. My separate remote gives me on/off capability, but it would be better if it controlled the speed of the fan as well.
The only issue I’d see with a floor fan is you can’d adjust anything while on the bike?
If you train in a cold environment you might want to turn it down, especially when in recovery periods. I have a tall version similar to the screwfix one which is in reach so I can grab the fan and alter the speed.
The reason I bought my fan was because of it’s review “This fan is way too powerful, even on the lowest setting”. Yes please I’ll take it! :slight_smile: You can probably get something cheaper, pretty sure I paid nearer to £30.
Not for you perhaps but I have decided to put a few quid away every week or so and buy a Wahoo Headwind for £200. Have seen them and know how powerful they are and someone responded to my question with a very cool review. Notice that - COOL - review
Vastly over-priced but I did think I would treat myself.
I have just calculated today that I have done 23K miles in the last 4 years of which over half are on the turbo and that ratio is much higher now than it was 4 years ago.
I used a 18 inches Rowenta fan, and it’s not bad so far. Someone else reported they were not good, and to be fair mine is new and hardly used. I will start using it again soon probably. It has 5 speeds, moves a bit of air and is not too noisy, but the clip is pretty shitty in that it’s not very movable/directionable in situ, they don’t oscillate and so can be a bitch to point where you want them when clipped to the tent pole. The clip is good though and there other places to clip it other than the poles. I hung mine from the ceiling struts in the end.
I got one of these in a sale from B&Q for about £12.
The quality of the stand isn’t good but I have never had to turn it up more than the first speed. Due to my bench/TV setup I can’t really get it far enough away from me and it could do with a 0.5 speed.
In the summer if really hot I have used a portable aircon unit but I don’t think I’ll need that again with this fan.
I’ve got 2 of those and they are excellent.
anyone used these?
No idea about that particular kind.
One I would highly recommend is
And there is a thread that mentions a discount of £10 if you use a code
GS10 I think.
Get ready to get cold!!!
I’d recommend this as well, very direct and noticeable airflow. Much more effective than a normal fan
