Secrets for keeping sweat off the drive train?
#1
I put a towel on the top tube sometimes. But still, the crank and front derailleur especially get covered with salt. Then I feel like I should hose down my bike way more often than I do, especially after a hard TR session.
Any secrets out there? Any pics from people who have solved this?
Thanks!
#2
More cooling! You can only do so much though depending on the humidity in your area. If you’re doing workouts at 80-100% you’re not going to get as much evaporative cooling.
I find that most people don’t have enough wind power from their vans.
#3
A powerful fan (or two) and you may not drip any sweat at all.
I have one Lasko max performance fan placed right in front of my front wheel, blowing over my handlebars at head and torso. Sweat evaporates right away. I don’t need a mat or towel.
#4
I find a cycling cap or terry cloth headband will soak up a lot of sweat from my head or redirect it away from dripping on my bike. Cap on backwards is especially good at this. Combine that with a sweat net, a fan, and a towel afross the handlebar for good measure and usually my frame is safe.
#5
I have A bike “thong” goes over your set and attached to your handle bars and wings out over your top tube. Should cover everything.
But I second more cooking as well
Thinvik [2-Pack] Bike Frame Sweat Guard Sweat Absorbs Prevent Bicycle from Corrosion for Bicycle Trainer Indoor Cycling Training https://www.amazon.com/dp/B07CG8QKBM/ref=cm_sw_r_cp_api_aBH-BbDCSQAPZ
#6
It’s been said in the thread a couple times already, but get a better fan! Seriously, ever since I got that lasko pro performance fan I barely sweat at all on the trainer.
#7
I’ll second the ideas above…a fan definitely cuts down on the amount that you sweat, but I also use an Elite bike thong, plus a towel over the handle bars.
