Switch from Speedplay to Assioma. What adjustments?
#1
Hi,
Hoping others might have switched from speedplay zero’s to power pedals (assioma) ?
What was it like and did you make adjustments to seat height, etc.
Also, what “float” or color of cleat felt similar?
Thanks
#2
Considering that the Zero cleats are fully adjustable via set screws, everyone may be using a different amount of rotation.
It is probably best to look at your shoes clipped in and see how much rotation you currently have setup. Then you can consider picking the Look style cleat with the closest amount of float to match.
