TR Workouts not reporting speed or distance to Strava, even with a speed sensor
workout-sync
#1
The last block of workouts I’ve done on TR are not reporting speed or distance to Strava. Anyone having the same issue? I know that the two metrics are irrelevant when it comes to indoor workouts, but I still like to track them.
#2
Hey Juan!
I would double check that your speed sensor is reporting speed properly. It is pretty common for the magnets to get jostled, leading to a lack of speed readings. To check that everything is set up properly:
  1. Go to your Devices Tab
  2. Ensure that your Speed Sensor is paired
  3. Pedal your bike to get the back wheel moving
  4. You should see a speed show up on the Speed/Cadence tile
  • If the Speed Reads as 0, the sensor is paired properly, but the magnet is not registering with the sensor
  • If the Speeds reads as an actual speed, but you still receive a “0” distance in Strava, then you may need to reach out to our Support Team. They can be reached at support@trainerroad.com and they will be happy to help you sort out this issue :slight_smile:
Cheers!
#3
Thank you for the reply, I will try the recommended fix.
#5
I’ve got a similar issue. TrainerRoad on my kickr core delivers laughably short distances for the effort i put in. A little over half of what id expect. Is there a setting in either trainerroad och wahoo fitness app that I should be changing to get more reasonable numbers? I do calibrate the core, it is in the latest firmware, i have power smootiing off.
Cheers,
Peter
#6
Put it in a different gear. The whole issue with ‘distance’ on a trainer in erg mode is that it means nothing, it’s is purely down to your gear ratio (unless you use a virtual cycling app which translates w/kg to speed based on the course profile).
Focus on TSS indoors and out.
#7
That’s funny. I’ve had the opposite problem, fighting with TR settings and sensors to record ZERO speed/distance to the ride data despite the Kickr sending imagined speed/distance numbers embedded in the power data.
I had it working briefly with a magnet speed sensor and wheel circumference set to 0, but this trick stopped working when I went back to the usual magnetless speed sensor.
In the end, I gave up and just record with a Garmin not connected to the Kickr or speed sensor and got my clean indoor files to export everywhere else. All I really lose are the lap splits :man_shrugging:
