I just got a new gravel bike and hoping to transfer over a similar fit to my road bike. I have set up to my best of the ability but know fore/aft could be improved. Having ridden it on single track including some steep descents, I am very happy with my handlebar position and stem length.
I have all the measurements of my road bike fit along with each individual bikes complete geometries. I am hoping to be able to correctly run a ratio to calculate out what the new saddle position should be. Where should I begin in order to correctly determine my position.
There are so many different variables introduced by frame, handlebar, and saddle geometries that I find it easiest just to ignore all of it and measure everything relative to the bottom bracket.
On the āsourceā bike, find the measurement between the centre of the bottom bracket and where you put your hands. This is your reach. Note that some places on the internet would say the reach measurement would be to the end of your stem, but this ignores the fact that different handlebars can put your hands further/closer to the bottom brackets. your hand position is ultimately what you care about.
Next, measure the vertical difference between the centre of the bottom bracket and the top of your handlebars where you put your hands. The easiest way to do this is measure the distance between the floor and your bottom bracket and the floor and your handlebars and then subtract the two. This is called your stack.
To transfer it over, just adjust the new bike to match your stack and reach measurements as closely as possible.
Saddle height is easy to transfer, since as long as youāre using the same pedals, shoes and crank length, it will be the same on both bikes. Saddle setback is harder since different saddles have different lengths and I find my default position on different types of saddles is slightly different. Iām not sure if this is the ārightā way, but I measure from the back of the saddle to my hand position on the source bike and then transfer that to the new bike, but only once Iāve already set up the stack, reach and saddle height. I find that gets me in the ballpark for saddle setback and then I make small adjustments from there.
Tape that knot to the center of the bottom bracket.
Tie another knot at the center of the saddle (or the tip if thatās easier)
Tie a third knot at your most common hand position (e.g. the hoods)
Now complete the loop/triangle back at the bottom bracket.
Cut off the extra string.
Now you have a āloopā of string, with three knots in it, and that loop can create the exact relations between the bottom bracket, saddle, and hand positions.
When you want to set up a new bike, repeat the process by taping the bottom bracket knot in place, using the 2nd knot to get the saddle height, then pulling the ātriangleā tight and setting your hand position where it needs to be.
Best thing about this technique is that it requires zero measuring/leveling tools. Added benefit is that the string packs down to zero space so you can carry it with you (e.g. when traveling and using a rental bike.)
How about taking 2 pictures of both bikes from same distance and overlay them in, say, some photo editing software, even powerpoint can do it. It would require to make photos semi transparent to see both bikes simultaneously. Then align photos horizontally (say take skewers as reference) and align bottom bracket for main referenceā¦
Not really good enough if you want something closer to mm accuracy. Youād have to absolutely nail position relative to the camera to even have a decent chance. The parallax effect of the single point camera view will lead to distortion.
It would take a tripod for the camera and exact positioning of the bikes base on a common reference (rear tire m\would be easiest). It would work for āclose countsā start, but short of actual tape measurements.
I bought a veloangle at the end of last year and used that to mirror my post-bike fit position on one bike to two others. There is a web app that costs money that converts the polar coordinates (angle / radius) to x-y coordinates. I found the useful in the initial setup but now am happy just to have the polar coordinates to mirror fit across multiple bikes. It helped me identify some issues with bikes I had built up and āadjustedā at the fitting shop that were not set to the right positions. It let me get sufficiently close that I cannot feel differences in my seated position relative to the pedals.
That seems like a hellishly complicated to get a bunch of simple dimensions.
Measure all the verticals from the floor and subtract to get the differences you need and with a wall behind the bike measure from the wall to all the same points to get the horizontals, subtract to get the differences you need, not sure what all the fuss is about.
I did this method except added in a pre drawn grid on the floor, then used a 3axis laser level to mark points on the ground (when the laser was on crank spindle for example). Could also use a 6ā level held against the wall together with tape measure to ensure youāre getting a horizontal distance.
Im trying to translate the fit i do on my SL7 to a Dogma F. Most im fine with but before i finish building the bike i want to make sure i cut the steerer to the correct length. This would be simple if the stack was the same but they are really different. Any advise on how to do this? Or is it just a case of getting a new bike fit before chopping?
Iād build the bike first then cut the steerer when Iām 100% confident everything is in the right place. Including a few test rides with the steerer tube either uncut or just trimmed a bit but will with enough left to adjust spacers if necessary. Not really a big issue taking stem off to cut the steerer tube. Or at least not an issue on traditional bikes, some of the integrated stem designs these days that might not be possible.
One option if you want to be able to move fits between bikes is the VeloAngle. A little pricey for individuals - better option for shops - but it is a way to very accurately transfer fit between bikes.
Surely you can install the stem and bars without the cables, measure it all up so you know the drop is correct, and then cut the steerer?
The stem must be installed first anyway so you can tell where to cut it.
Yes but you also canāt do that if you just go off an online geometry calc of the stack and cut it. Technically could do a quick ride with terrible looking externally routed cables, or a quick spin on a trainer / rollers.
