Tri BIke Sizing Question
bike
#1
I have a 2010 Cervelo P2, size 56, that I am likely to be selling to a friend. I loaned it to them to try out, and don’t have the bike to take all the typical XY dimensions for fit. But here is what I know for now with regards to sizing.
  • I am 5’ 10" [178 cm], with 34" [86 cm] actual inseam length Long legs with a short torso.
  • The P2 has a short and high angle stem (I need to measure but probably around 90 mm x 30* positive), and is installed with about 20 mm of spacers between the HS cap and the stem.
  • Arm pads have the taller spacers (maybe 20 mm tall). I end up with about 70 mm drop from the saddle to the top of the pads, based on a 770 cm saddle height.
  • I have the saddle mount installed in the forward hole of the seat post.
  • Sitero saddle installed rearward with about 15 mm of the leading saddle rail exposed, and much more than that behind the clamp. Effectively a fairly rear mount location.
  • It fits, but might be a bit on the long side for the TT length.
I am looking at the Specialized Shiv Tri for the next bike and torn on sizing.
The Specialized chart has me on the bubble.
  • I know these are generally just a starting point for sizing.
  • I seem to remember reading on Slowtwitch forums that you usually size down when you are between sizes.
I made a geometry comparison between the Cervelo 56cm and the Shiv in Medium and Large. I am missing some info on the Cervelo since it is older and I have issues finding more detailed charts.
The Cervelo seems to be about in the middle of the Shivs for the most part.
I am looking for some guidance, as I have to buy without the ability to test fit in person.
I can get my Cervelo for more detailed measurements and pics of me on it for reference.
Thanks for any guidance you can offer.
#2
Is there someone around you that will do a pre purchase fit? They put you on a performance cycle or guru or something like that and adjust it until your comfortable/position you want. After they have that it spits out dimensions/bike thats will fit you. Some places will take the price of the fit off the cost of the bike if you buy through them. I’d be a little weary of that because I’m paranoid they would make me fit one of the brands they sell but that’s probably unrealistic. Definitely worth doing if you have that option around you. I didn’t do that and it ended being much more of a pain in the butt and expensive.
#3
Oddly enough, I am actually a fitter. I just don’t have access to an adjustable sizing bike to play with for testing. Best I can do is grab some random road bikes and try to match fit, and they are very different for seat tube angle.
No tri bikes on the floor in my shop or the local area in other shops. So I am left to go from current bike fit and comparing geo charts. I’ve done it with other bikes, but I know tri bikes far less than road and MTB.
#4
Gotcha. Might be worth trying to find a shop with some sort of fit cycle. The measurements don’t really transfer all that well sometimes because of all the angles and the different contact points. I won’t buy another without getting pre-fit.
