Tubeless road setup with an on-wheel trainer?
#1
Hey all,
I’ve been using TR with my road bike, clinchers, and a pre-2017 KICKR Snap (wheel on trainer). I was planning to switch to tubeless setup and so I was wondering if folks had any advice about using tubeless road tires with a wheel on trainer. Does it work ok? Do you run higher pressures on the trainer than on the road? Thanks in advance.
#2
I use 25mm Pro Ones on my KK RM.
I’ll run 100psi on the trainer (just for consistency ride-to-ride and a little less muddy feeling), and they’re noticably quieter and smoother than the Zaffiros I replaced with the Ones.
When I take it outside, I just drop the psis to 85, and it’s all good. :+1:t2:
#3
Thanks. I’m planning on using 23mm Pro Ones, so it’s good to hear those work well for you.
