Virtual power gone mad due to low temperatures?
power-issues
#1
Just wondering if this has happened to anyone else? Not sure if it’s a problem with my old iPad or maybe with the trainer slipping on a cold drum?
#2
I once did a trainer ride outdoors when it warmed up to -5C or something one winter because it was a sunny day. Didn’t have any dropouts or issues.
It could be one of your sensors. When the battery is low on the speed or cadence sensor and I lose the connection, this happens. I think it only happens if the speed sensor isn’t picking up.
#3
Not directly related to your question, but I’ve noticed power between Kickr and TR lagging at the beginning of workout since it got cold in my basement. It’s taking 10-20 seconds to come up to target power when the workout starts. No issues or dropouts after it reaches target. Just the lagging at the beginning.
#4
Trying to do a ramp test but this is very demotivating. I’m thinking it’s either the weather being cold in the UK or the TestFlight update.
#5
I had something a bit like that when the battery on my speed sensor was running out. Could you check that?
#6
Wipe down the tyre too, excess rubber messes up the resistance which shows up on the power stats.
