Wahoo Kickr low resistance
trainer
#1
Dear,
I’m having trouble with my wahoo kickr getting way to low resistance as i’m running a MTB 32T 11-42t
I cant even reach 200 watts before hitting my hardest gear.
No problems in erg mode ofcourse, but how can I get past this in normal mode?
Can I set some kind of base wattage?
Device: Wahoo Kickr Core
Thx!
#2
Changing the resistance setting should do it.
#3
On my kickr? Where?
#4
No, in the TrainerRoad app.
What platform do you use to run the app?
#5
yes but i’m not having any resistance problems in erg mode, this works fine.
It’s only what i’m using “standard” not erg mode that i’m just going 120rpm and 150watts in biggest gear :frowning:
#6
Right, and you can adjust the precise amount of resistance in “Resistance” mode.
This isn’t perfect, but it mentions the mode. Switch to “Resistance” and you can adjust it to anything from 0-100% in 1% increments. This controls the base level, and you can use shifting to cover the main differences in your workout.
