In a quest for more accurate cadence data, I’m considering an external cadence sensor (Wahoo RPM). Properly paired, will the ext cad sensor data override that which is provided by the new KK InRide3? Will this create any conflicts? And, will TR receive, read and display ext sensor data accurately?
Yes, the sensor readings will override the KK cadence without any conflicts and TR will read and display the sensor data. Any designated sensor (like a cadence sensor) will override the numbers that come from a trainer unless (in the case of a power meter) you have your power meter set to “cadence only”.
